Generalized n-Dimensional Rigid Registration: Theory and Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Cybernetics Année : 2023
The generalized rigid registration problem in high-dimensional Euclidean spaces is studied. The loss function is minimized with an equivalent error formulation by the Cayley formula. The closed-form linear least-square solution to such a problem is derived which generates the registration covariances, i.e., uncertainty information of rotation and translation, providing quite accurate probabilistic descriptions. Simulation results indicate the correctness of the proposed method and also present its efficiency on computation-time consumption, compared with previous algorithms using singular value decomposition (SVD) and linear matrix inequality (LMI). The proposed scheme is then applied to an interpolation problem on the special Euclidean group SE(n) with covariance-preserving functionality. Finally, experiments on covariance-aided Lidar mapping show practical superiority in robotic navigation.
1_bare_jrnl.pdf (7.17 Mo) Télécharger le fichier
hal-03648274 , version 1 (09-11-2022)
Jin Wu, Miaomiao Wang, Hassen Fourati, Hui Li, Yilong Zhu, et al.. Generalized n-Dimensional Rigid Registration: Theory and Applications. IEEE Transactions on Cybernetics, 2023, 53 (2), pp.927-940. ⟨10.1109/tcyb.2022.3168938⟩. ⟨hal-03648274⟩
73 Consultations
20 Téléchargements
