GraphCite: Citation Intent Classification in Scientific Publications via Graph Embeddings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Citations are crucial in scientific works as they help position a new publication. Each citation carries a particular intent, for example, to highlight the importance of a problem or to compare against results provided by another method. The authors' intent when making a new citation has been studied to understand the evolution of a field over time or to make recommendations for further citations. In this work, we address the task of citation intent prediction from a new perspective. In addition to textual clues present in the citation phrase, we also consider the citation graph, leveraging high-level information of citation patterns. In this novel setting, we perform a thorough experimental evaluation of graph-based models for intent prediction. We show that our model, GraphCite, improves significantly upon models that take into consideration only the citation phrase. Our code is available online.
graphcite.pdf (660.44 Ko) Télécharger le fichier
hal-03648498 , version 1 (21-04-2022)
Copyright (Tous droits réservés)
  • HAL Id : hal-03648498 , version 1
Dan Berrebbi, Nicolas Huynh, Oana Balalau. GraphCite: Citation Intent Classification in Scientific Publications via Graph Embeddings. 2nd International Workshop on Scientific Knowledge: Representation, Discovery, and Assessment, Apr 2022, Lyon / Virtual, France. ⟨hal-03648498⟩
155 Consultations
333 Téléchargements
