On discrete spectra of Bergman-Toeplitz operators with harmonic symbols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
In the present article, we study the discrete spectrum of certain bounded Toeplitz operators with harmonic symbol on a Bergman space. Using the methods of classical perturbaton theory and recent results by Borichev-Golinskii-Kupin and Favorov-Golinskii, we obtain a quantitative result on the distribution of the discrete spectrum of the operator in the unbounded (outer) component of its Fredholm set.
bt-operators.pdf (276.13 Ko) Télécharger le fichier
hal-03650364 , version 1 (26-04-2022)
Paternité
Leonid Golinskii, Stanislas Kupin, Masimba Nemaire, Juliette Leblond. On discrete spectra of Bergman-Toeplitz operators with harmonic symbols. From Complex Analysis to Operator Theory: A Panorama In Memory of Sergey Naboko, 291, Springer International Publishing, 2023, Operator Theory: Advances and Applications, ⟨10.1007/978-3-031-31139-0⟩. ⟨hal-03650364⟩
47 Consultations
43 Téléchargements
