Revisiting the Random Subset Sum problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
The average properties of the well-known \emph{Subset Sum Problem} can be studied by the means of its randomised version, where we are given a target value $z$, random variables $X_1, \ldots, X_n$, and an error parameter $\varepsilon > 0$, and we seek a subset of the $X_i$'s whose sum approximates $z$ up to error~$\varepsilon$. In this setup, it has been shown that, under mild assumptions on the distribution of the random variables, a sample of size $\mathcal{O}\left(\log (1/\varepsilon)\right)$ suffices to obtain, with high probability, approximations for all values in~$[-1/2, 1/2]$. Recently, this result has been rediscovered outside the algorithms community, enabling meaningful progress in other fields. In this work we present an alternative proof for this theorem, with a more direct approach and resourcing to more elementary tools, in the hope of disseminating it even further.
RandomSubsetSum.pdf (439.58 Ko) Télécharger le fichier
hal-03654720 , version 1 (28-04-2022)
hal-03654720 , version 2 (30-03-2023)
Arthur da Cunha, Francesco d'Amore, Frédéric Giroire, Hicham Lesfari, Emanuele Natale, et al.. Revisiting the Random Subset Sum problem. 2022. ⟨hal-03654720v1⟩
217 Consultations
234 Téléchargements
