A Sparse Non-parametric BRDF Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2022
This paper presents a novel sparse non-parametric BRDF model derived using a machine learning approach to represent the space of possible BRDFs using a set of multidimensional sub-spaces, or dictionaries. By training the dictionaries under a sparsity constraint, the model guarantees high quality representations with minimal storage requirements and an inherent clustering of the BDRF-space. The model can be trained once and then reused to represent a wide variety of measured BRDFs. Moreover, the proposed method is flexible to incorporate new unobserved data sets, parameterizations, and transformations. In addition, we show that any two, or more, BRDFs can be smoothly interpolated in the coefficient space of the model rather than the significantly higher-dimensional BRDF space. The proposed sparse BRDF model is evaluated using the MERL, DTU and RGL-EPFL BRDF databases. Experimental results show that the proposed approach results inabout 9.75dB higher SNR on average for rendered images as compared to current state-of-the-art models.
TOG2021_non_parametric_sparse_brdf_final.pdf (17.51 Mo) Télécharger le fichier
hal-03654734 , version 1 (28-04-2022)
Tanaboon Tongbuasirilai, Jonas Unger, Christine Guillemot, Ehsan Miandji. A Sparse Non-parametric BRDF Model. ACM Transactions on Graphics, 2022, pp.1-18. ⟨10.1145/3533427⟩. ⟨hal-03654734⟩
2046 Consultations
143 Téléchargements
