Evaluation of MRI-based machine learning approaches for computer-aided diagnosis of dementia in a clinical data warehouse - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
A variety of algorithms have been proposed for computer-aided diagnosis of dementia from anatomical MRI. These approaches achieve high accuracy when applied to research data sets but their performance on real-life clinical routine data has not been evaluated yet. The aim of this work was to study the performance of such approaches on clinical routine data, based on a hospital data warehouse, and to compare the results to those obtained on a research data set. The clinical data set was extracted from the hospital data warehouse of the Greater Paris area, which includes 39 different hospitals. The research set was composed of data from the Alzheimer's Disease Neuroimaging Initiative data set. In the clinical set, the population of interest was identified by exploiting the diagnostic codes from the 10th revision of the International Classification of Diseases that are assigned to each patient. We studied how the imbalance of the training sets, in terms of contrast agent injection and image quality, may bias the results. We demonstrated that computer-aided diagnosis performance was strongly biased upwards (over 17 percent points of balanced accuracy) by the confounders of image quality and contrast agent injection, a phenomenon known as the Clever Hans effect. When these biases were removed, the performance was very poor. In any case, the performance was considerably lower than on the research data set. Our study highlights that there are still considerable challenges for translating dementia CAD systems to clinical routine.
CAD_SimonaBottani.pdf (432.76 Ko) Télécharger le fichier
hal-03656136 , version 1 (01-05-2022)
hal-03656136 , version 2 (04-06-2023)
  • HAL Id : hal-03656136 , version 1
Simona Bottani, Ninon Burgos, Aurélien Maire, Dario Saracino, Sebastian Ströer, et al.. Evaluation of MRI-based machine learning approaches for computer-aided diagnosis of dementia in a clinical data warehouse. 2022. ⟨hal-03656136v1⟩
246 Consultations
319 Téléchargements
