G1-smooth Biquintic Approximation of Catmull-Clark Subdivision Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this paper a construction of a globally G1 family of Bézier surfaces, defined by smoothing masks approximating the well-known Catmull-Clark (CC) subdivision surface is presented. The resulting surface is a collection of Bézier patches, which are bicubic C2 around regular vertices and biquintic G1 around extraordinary vertices (and C1 on their one-rings vertices). Each Bézier point is computed using a locally defined mask around the neighboring mesh vertices. To define G1 conditions, we assign quadratic gluing data around extraordinary vertices that depend solely on their valence and we use degree five patches to satisfy these G1 constraints. We explore the space of possible solutions, considering several projections on the solution space leading to different explicit formulas for the masks. Certain control points are computed by means of degree elevation of the C0 scheme of Loop and Schaefer [22], while for others, explicit masks are deduced by providing closed-form solutions of the G1 conditions, expressed in terms of the masks. We come up with four different schemes and conduct curvature analysis on an extensive benchmark in order to assert the quality of the resulting surfaces and identify the ones that lead to the best result, both visually and numerically. We demonstrate that the resulting surfaces converge quadratically to the CC limit when the mesh is subdivided.
G1ACC.pdf (6.61 Mo) Télécharger le fichier
Format : Figure, Image
hal-03656945 , version 1 (02-05-2022)
hal-03656945 , version 2 (04-05-2022)
  • HAL Id : hal-03656945 , version 1
Michelangelo Marsala, Angelos Mantzaflaris, Bernard Mourrain. G1-smooth Biquintic Approximation of Catmull-Clark Subdivision Surfaces. 2022. ⟨hal-03656945v1⟩
244 Consultations
213 Téléchargements
