Numerical issues and turnpike phenomenon in optimal shape design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2022
This article follows and complements where we have established the turnpike property for some optimal shape design problems. Considering linear parabolic partial differential equations where the shapes to be optimized acts as a source term, we want to minimize a quadratic criterion. Existence of optimal shapes is proved under some appropriate assumptions. We prove and provide numerical evidence of the turnpike phenomenon for those optimal shapes, meaning that the extremal time-varying optimal solution remains essentially stationary; actually, it remains essentially close to the optimal solution of an associated static problem.
LTZ_RICAM.pdf (3.78 Mo) Télécharger le fichier
hal-03660786 , version 1 (06-05-2022)
Gontran Lance, Emmanuel Trélat, Enrique Zuazua. Numerical issues and turnpike phenomenon in optimal shape design. Roland Herzog; Matthias Heinkenschloss; Dante Kalise; Georg Stadler; Emmanuel Trélat. Optimization and control for partial differential equations: Uncertainty quantification, open and closed-loop control, and shape optimization, 29, De Gruyter, pp.343-366, 2022, Radon Series on Computational and Applied Mathematics, 9783110695960. ⟨10.1515/9783110695984⟩. ⟨hal-03660786⟩
65 Consultations
58 Téléchargements
