A σ3 condition for arbitrarily partitionable graphs
A graph $G$ of order $n$ is arbitrarily partitionable (AP for short) if, for every partition $(\lambda_1,\dots,\lambda_p)$ of $n$, there is a partition $(V_1,\dots,V_p)$ of $V(G)$ such that $G[V_i]$ is a connected graph of order $\lambda_i$ for every $i \in \{1,\dots,p\}$. Several aspects of AP graphs have been investigated to date, including their connection to Hamiltonian graphs and traceable graphs. Every traceable graph (and, thus, Hamiltonian graph) is indeed known to be AP, and a line of research on AP graphs is thus about weakening, to APness, known sufficient conditions for graphs to be Hamiltonian or traceable.
In this work, we provide a sufficient condition for APness involving the parameter $\overline{\sigma_3}$, where, for a given graph $G$, the parameter $\overline{\sigma_3}(G)$ is defined as the maximum value of $d(u)+d(v)+d(w)-|N(u) \cap N(v) \cap N(w)|$ for a set $\{u,v,w\}$ of three pairwise independent vertices $u$, $v$, and $w$ of $G$. Flandrin, Jung, and Li proved that any graph $G$ of order $n$ is Hamitonian provided $\overline{\sigma_3}(G) \geq n$, and traceable provided $\overline{\sigma_3}(G) \geq n-1$. Unfortunately, we exhibit examples showing that having $\overline{\sigma_3}(G) \geq n-2$ is not a guarantee for $G$ to be AP. However, we prove that $G$ is AP provided $G$ is $2$-connected, $\overline{\sigma_3}(G) \geq n-2$, and $G$ has a perfect matching or quasi-perfect matching.
