Joint optimization of diffusion probabilistic-based multichannel speech enhancement with far-field speaker verification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Today's smart devices using speaker verification are getting equipped with multiple microphones resulting in improving spatial ambiguity and directivity. However, unlike any other speech-based applications, the performance of speaker verification degrades in far-field scenarios due to the adverse effects of a noisy environment and room reverberation. This paper presents a novel multichannel speech enhancement module based on the diffusion probabilistic model. It is used as the front-end of the ECAPA-TDNN speaker verification system in far-field scenarios under a noisy-reverberant environment. The proposed system incorporates a two-stage training approach. In the first stage, both speech enhancement and speaker verification modules are trained individually. In the second stage, both the modules are combined to jointly trained them. We use similaritypreserving knowledge distillation loss that guides the network to produce similar activation for enhanced signals to that of clean speech signals. Using joint optimization with knowledge distillation loss achieved the best performance on both the evaluation composed of synthetic clips similar to those used at training and on unseen recorded clips from the VOiCES dataset.
INTERSPEECH2022.pdf (417.63 Ko) Télécharger le fichier
hal-03671583 , version 1 (18-05-2022)
  • HAL Id : hal-03671583 , version 1
Sandipana Dowerah, Romain Serizel, Denis Jouvet, M Mohammadamini, Driss Matrouf. Joint optimization of diffusion probabilistic-based multichannel speech enhancement with far-field speaker verification. IEEE SLT 2022, Jan 2023, Doha, Qatar. ⟨hal-03671583v1⟩
443 Consultations
377 Téléchargements
