Automated design of dynamic programming schemes for RNA folding with pseudoknots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Despite being a textbook application of dynamic programming (DP) and routine task in RNA structure analysis, RNA secondary structure prediction remains challenging whenever pseudoknots come into play. To circumvent the NP-hardness of energy minimization in realistic energy models, specialized algorithms have been proposed for restricted conformation classes that capture the most frequently observed configurations. While these methods rely on hand-crafted DP schemes, we generalize and fully automatize the design of DP pseudoknot prediction algorithms. We formalize the problem of designing DP algorithms for an (infinite) class of conformations, modeled by (a finte number of) fatgraphs, and automatically build DP schemes minimizing their algorithmic complexity. We propose an algorithm for the problem, based on the tree-decomposition of a well-chosen representative structure, which we simplify and reinterpret as a DP scheme. The algorithm is fixed-parameter tractable for the tree-width tw of the fatgraph, and its output represents a O(n tw+1) algorithm for predicting the MFE folding of an RNA of length n. Our general framework supports general energy models, partition function computations, recursive substructures and partial folding, and could pave the way for algebraic dynamic programming beyond the context-free case.
auto_DP(3).pdf (1.75 Mo) Télécharger le fichier
hal-03676377 , version 1 (23-05-2022)
hal-03676377 , version 2 (11-08-2022)
Paternité
  • HAL Id : hal-03676377 , version 1
Bertrand Marchand, Sebastian Will, Sarah Berkemer, Laurent Bulteau, Yann Ponty. Automated design of dynamic programming schemes for RNA folding with pseudoknots. WABI 2022 - 22nd Workshop on Algorithms in Bioinformatics, Sep 2022, Potsdam, Germany. ⟨hal-03676377v1⟩
231 Consultations
126 Téléchargements
