A systematic approach to Lyapunov analyses of continuous-time models in convex optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
First-order methods are often analyzed via their continuous-time models, where their worst-case convergence properties are usually approached via Lyapunov functions. In this work, we provide a systematic and principled approach to find and verify Lyapunov functions for classes of ordinary and stochastic differential equations. More precisely, we extend the performance estimation framework, originally proposed by Drori and Teboulle [10], to continuous-time models. We retrieve convergence results comparable to those of discrete methods using fewer assumptions and convexity inequalities, and provide new results for stochastic accelerated gradient flows.
main.pdf (480.76 Ko) Télécharger le fichier
hal-03677528 , version 1 (24-05-2022)
hal-03677528 , version 2 (25-05-2022)
hal-03677528 , version 3 (07-03-2024)
Céline Moucer, Adrien Taylor, Francis Bach. A systematic approach to Lyapunov analyses of continuous-time models in convex optimization. 2022. ⟨hal-03677528v2⟩
124 Consultations
188 Téléchargements
