Identification of fungal trehalose for the diagnosis of invasive candidiasis by mass spectrometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biochimica et Biophysica Acta (BBA) - General Subjects Année : 2022
The rapidity of the diagnosis of invasive candidiasis (IC) is crucial to allow the early introduction of antifungal therapy that dramatically increases the survival rate of patients. Early diagnosis is unfortunately often delayed because Candida blood culture, the gold standard diagnostic test, is positive in only 50% of cases of IC and takes several days to obtain this result. Complementary non-culture-based methods relying on the detection of Candida cell wall polysaccharides in the serum, β-glucans and mannans, by enzymatic and immunological reagents have been successfully developed to allow a more efficient patients care. We have previously demonstrated that detection of circulating glycans by mass spectrometry could provide a reliable and cost-effective early diagnosis method called MS-DS for Mass Spectrometry of Di-Saccharide. Here, by comparing patient's sera and Candida albicans strains deficient in carbohydrates synthesis, we demonstrate that trehalose derived from fungal metabolism can be specifically targeted by MS-DS to allow early diagnosis. In particular, the use of C. albicans strains deficient in the synthesis of trehalose synthesizing enzymes Tps1 and Tps2 show that MS-DS results were correlated to the metabolism of trehalose. Finally, we demonstrate that the performance of the IC diagnosis can be significantly improved by using high resolution mass spectrometry, which opens new perspectives in the management of the disease.
P22.01 Mery-BBA-2021.pdf (1.09 Mo) Télécharger le fichier
hal-03677656 , version 1 (24-05-2022)
Alexandre Mery, Samir Jawhara, Nadine Francois, Marjorie Cornu, Julien Poissy, et al.. Identification of fungal trehalose for the diagnosis of invasive candidiasis by mass spectrometry. Biochimica et Biophysica Acta (BBA) - General Subjects, 2022, 1866 (4), pp.130083. ⟨10.1016/j.bbagen.2022.130083⟩. ⟨hal-03677656⟩
Collections
CNRS UNIV-LILLE
52 Consultations
120 Téléchargements
