Cosmology with cosmic web environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Astronomy and Astrophysics - A&A Année : 2022
We undertake the first comprehensive and quantitative real-space analysis of the cosmological information content in the environments of the cosmic web (voids, filaments, walls, and nodes) up to non-linear scales, k = 0.5 h Mpc−1. Relying on the large set of N-body simulations from the Quijote suite, the environments are defined through the eigenvalues of the tidal tensor and the Fisher formalism is used to assess the constraining power of the spectra derived in each of the four environments and their combination. Our results show that there is more information available in the environment-dependent power spectra – both individually and when combined – than in the matter power spectrum. By breaking some key degeneracies between parameters of the cosmological model such as Mν–σ8 or Ωm–σ8, the power spectra computed in identified environments improve the constraints on cosmological parameters by factors of ∼15 for the summed neutrino mass Mν and ∼8 for the matter density Ωm over those derived from the matter power spectrum. We show that these tighter constraints are obtained for a wide range of the maximum scale, from kmax = 0.1 h Mpc−1 to highly non-linear regimes with kmax = 0.5 h Mpc−1. We also report an eight times higher value of the signal-to-noise ratio for the combination of environment-dependent power spectra than for the matter spectrum. Importantly, we show that all the results presented here are robust to variations of the parameters defining the environments, suggesting a robustness to the definition we chose to extract them.
aa42852-21.pdf (999.06 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03677762 , version 1 (24-05-2022)
Tony Bonnaire, Nabila Aghanim, Joseph Kuruvilla, Aurélien Decelle. Cosmology with cosmic web environments: I. Real-space power spectra. Astronomy and Astrophysics - A&A, 2022, 661, pp.A146. ⟨10.1051/0004-6361/202142852⟩. ⟨hal-03677762⟩
111 Consultations
61 Téléchargements
