A single-source C++20 HLS flow for function evaluation on FPGA and beyond - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a framework to reuse the intelligence of RTL generators in a single-source HLS setting. This framework is illustrated by a C++ fixed-point library to generate mathematical function evaluator. A compiler flow from C++20 to Vivado IPs has been developed to make the library usable with Vitis HLS. This flow is demonstrated on two applications: an adder for the logarithmic number system, and additive sound synthesis. These experiments show that the approach allows to easily tune the precision of the types used in the application. They also demonstrate the ability to generate arbitrary function evaluator at the required precision.
2022_HEART_HLS_FixFunction.pdf (780.17 Ko) Télécharger le fichier
hal-03684757 , version 1 (01-06-2022)
  • HAL Id : hal-03684757 , version 1
Luc Forget, Gauthier Harnisch, Ronan Keryell, Florent de Dinechin. A single-source C++20 HLS flow for function evaluation on FPGA and beyond. HEART 2022 - 12th International Symposium on Highly Efficient Accelerators and Reconfigurable Technologies, Jun 2022, Tsukuba, Japan. ⟨hal-03684757⟩
142 Consultations
509 Téléchargements
