An Interference to Noise Ratio Handover mechanism for Mobile Visible Light Communication Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Meysam Mayahi
  • Fonction : Auteur
  • PersonId : 1122565
Antonio Costanzo
  • Fonction : Auteur
  • PersonId : 1026791
Valeria Loscrì
  • Fonction : Auteur
  • PersonId : 1084587
Visible Light Communication (VLC) is recognized as a complement communication technology that meets many hurdles of Radio Frequency (RF) systems. For example, VLC overcomes the limited RF spectrum resources for mobile users, even though its application demands an effective mechanism to handover among the different devices, in order to keep the connectivity consistent. In this paper, a new handover mechanism is introduced for mobile VLC nodes, based on a real time evaluation of the Interference-to-Noise Ratio (INR). This mechanism is coupled with four adaptive modulation schemes to further enhance the data rate. The communication system is evaluated at 0.15 mps and 0.3 mps velocities for different parameters i.e., handover rate, delivered data per handover and handover delay ratio, through an extensive simulated campaign. An experimental validation carried out through software-defined approach, considering a small-scale scenario and low power Light Emitting Diodes (LEDs). A perfect results alignment between simulation and measurement show how suggested INR-based mechanism overcomes classical SNR-based handover for all performance parameters evaluated in this study.
CSNDSP2022.pdf (1.74 Mo) Télécharger le fichier
hal-03689831 , version 1 (07-06-2022)
  • HAL Id : hal-03689831 , version 1
Meysam Mayahi, Antonio Costanzo, Valeria Loscrì, Anna Vegni. An Interference to Noise Ratio Handover mechanism for Mobile Visible Light Communication Networks. CSNDSP 2022 - 13th International Symposium on Communication Systems, Networks and Digital Signal Processing, Jul 2022, Porto, Portugal. ⟨hal-03689831⟩
Collections
INRIA INRIA2
63 Consultations
147 Téléchargements
