Rendez-vous Based Drift Diagnosis Algorithm For Sensor Networks Towards In Situ Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automation Science and Engineering Année : 2022
In recent years, low-cost sensors have raised strong interest for environmental monitoring applications. These instruments often suffer from degraded data quality. Notably, they are prone to drift. It can be mitigated with costly periodic calibrations. To reduce this cost, in situ calibration strategies have emerged, enabling the recalibration of instruments while leaving them in the field. However, they rarely identify which instruments actually need a calibration because of drift, so that in situ calibration may instead degrade performances. Therefore, a novel drift detection algorithm is presented in this work, exploiting the concept of rendezvous between measuring instruments. Its originality lies mainly in the comparisons of values determining the state of the instruments, for which the quality of the measurement results is taken into account. It defines the concept of compatibility between measurement results. A case study is developed, showing an accuracy of 88% for correct detection of drifting instruments. The results of the diagnosis algorithm are then combined with calibration approaches. Results show a significant improvement of the measurement results. Notably, an increase of 15% of the coefficient of determination of the linear regression between their true values and the measured values is observed with the correction and the error on the slope and on the intercept respectively is reduced by 50% and 60% at least.
Article_diagnosis.pdf (7.57 Mo) Télécharger le fichier
hal-03692440 , version 1 (09-06-2022)
Florentin Delaine, Bérengère Lebental, Hervé Rivano. Rendez-vous Based Drift Diagnosis Algorithm For Sensor Networks Towards In Situ Calibration. IEEE Transactions on Automation Science and Engineering, 2022, ⟨10.1109/TASE.2022.3182289⟩. ⟨hal-03692440⟩
85 Consultations
100 Téléchargements
