On the square-root approximation finite volume scheme for nonlinear drift-diffusion equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We study a finite volume scheme for the approximation of the solution to convection diffusion equations with nonlinear convection and Robin boundary conditions. The scheme builds on the interpretation of such a continuous equation as the hydrodynamic limit of some simple exclusion jump process. We show that the scheme admits a unique discrete solution, that the natural bounds on the solution are preserved, and that it encodes the second principle of thermodynamics in the sense that some free energy is dissipated along time. The convergence of the scheme is then rigorously established thanks to compactness arguments. Numerical simulations are finally provided, highlighting the overall good behavior of the scheme.
SQRA_Lacunaire_revised.pdf (952.19 Ko) Télécharger le fichier
hal-03693887 , version 1 (13-06-2022)
hal-03693887 , version 2 (05-09-2022)
hal-03693887 , version 3 (12-09-2022)
  • HAL Id : hal-03693887 , version 2
Clément Cancès, Juliette Venel. On the square-root approximation finite volume scheme for nonlinear drift-diffusion equations. 2022. ⟨hal-03693887v2⟩
131 Consultations
84 Téléchargements
