Six Methods for Transforming Layered Hypergraphs to Apply Layered Graph Layout Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2022
Hypergraphs are a generalization of graphs in which edges (hyperedges) can connect more than two vertices-as opposed to ordinary graphs where edges involve only two vertices. Hypergraphs are a fairly common data structure but there is little consensus on how to visualize them. To optimize a hypergraph drawing for readability, we need a layout algorithm. Common graph layout algorithms only consider ordinary graphs and do not take hyperedges into account. We focus on layered hypergraphs, a particular class of hypergraphs that, like layered graphs, assigns every vertex to a layer, and the vertices in a layer are drawn aligned on a linear axis with the axes arranged in parallel. In this paper, we propose a general method to apply layered graph layout algorithms to layered hypergraphs. We introduce six different transformations for layered hypergraphs. The choice of transformation affects the subsequent graph layout algorithm in terms of computational performance and readability of the results. Thus, we perform a comparative evaluation of these transformations in terms of number of crossings, edge length, and impact on performance. We also provide two case studies showing how our transformations can be applied to real-life use cases. A copy of this paper with all appendices and supplemental material is available at osf.io/grvwu.
v41i3pp259-270.pdf (1.96 Mo) Télécharger le fichier
Format : Figure, Image
Licence : CC BY NC - Paternité - Pas d'utilisation commerciale
hal-03694781 , version 1 (14-06-2022)
Sara Di Bartolomeo, Alexis Pister, Paolo Buono, Catherine Plaisant, Cody Dunne, et al.. Six Methods for Transforming Layered Hypergraphs to Apply Layered Graph Layout Algorithms. Computer Graphics Forum, 2022, EuroVis 2022 - Conference Proceedings, 41 (3), pp.1467-8659. ⟨10.1111/cgf.14538⟩. ⟨hal-03694781⟩
96 Consultations
324 Téléchargements
