Pressure jump and radial stationary solutions of the degenerate Cahn-Hilliard equation (Extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mécanique Année : 2023
The Cahn-Hilliard equation with degenerate mobility is used in several areas including the modeling of living tissues. We are interested in quantifying the pressure jump at the interface in the case of incompressible flows. To do so, we include an external force and consider stationary radial solutions. This allows us to compute the pressure jump in the small dispersion regime. We also characterize compactly supported stationary solutions in the incompressible case, prove the incompressible limit and prove convergence of the parabolic problems to stationary states.
CH_radial_pde.pdf (620.29 Ko) Télécharger le fichier
hal-03696545 , version 1 (16-06-2022)
hal-03696545 , version 2 (02-11-2022)
hal-03696545 , version 3 (13-01-2023)
Charles Elbar, Benoît Perthame, Jakub Skrzeczkowski. Pressure jump and radial stationary solutions of the degenerate Cahn-Hilliard equation (Extended version). Comptes Rendus. Mécanique, In press. ⟨hal-03696545v3⟩
113 Consultations
47 Téléchargements
