A penalty method for constrained Multibody kinematics optimisation using a Levenberg-Marquardt algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Biomechanics and Biomedical Engineering Année : 2022
An alternative method for solving constrained Multibody kinematics optimisation using a penalty method on constraints and a Levenberg-Marquardt algorithm is proposed. It is compared to an optimisation resolution with hard kinematic constraints. These methods are applied to two pairs of experiments and models. The penalty method was at least 20 times faster than the optimisation resolution while keeping similar reconstruction errors and constraints violation. The potential of the method is shown to accurately solve the Multibody kinematics optimisation problem in a reasonable amount of time. A computational gain lies in implementing this resolution with a compiled and optimised program code.
A_penalty_method__for_constrained_multibody_kinematic_optimisation_using_a_Levenberg_Marquardt_algorithm.pdf (4.46 Mo) Télécharger le fichier
hal-03697267 , version 1 (16-06-2022)
  • HAL Id : hal-03697267 , version 1
Claire Livet, Théo Rouvier, Christophe Sauret, Hélène Pillet, Georges Dumont, et al.. A penalty method for constrained Multibody kinematics optimisation using a Levenberg-Marquardt algorithm. Computer Methods in Biomechanics and Biomedical Engineering, 2022, pp.1-27. ⟨hal-03697267⟩
194 Consultations
228 Téléchargements
