Robust Estimation of Laplacian Constrained Gaussian Graphical Models with Trimmed Non-convex Regularization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of discovering a structure that fits a collection of vector data is of crucial importance for a variety of applications. Such problems can be framed as Laplacian constrained Gaussian Graphical Model inference. Existing algorithms rely on the assumption that all the available observations are drawn from the same Multivariate Gaussian distribution. However, in practice it is common to find scenarios where the datasets are contaminated with a certain number of outliers. The purpose of this work is to address that problem. We propose a robust method based on Trimmed Least Squares that copes with the presence of corrupted samples. We provide statistical guarantees on the estimation error and present results on simulated data.
main.pdf (416.98 Ko) Télécharger le fichier
hal-03697993 , version 1 (17-06-2022)
hal-03697993 , version 2 (05-07-2022)
  • HAL Id : hal-03697993 , version 2
Mariana Vargas Vieyra. Robust Estimation of Laplacian Constrained Gaussian Graphical Models with Trimmed Non-convex Regularization. PODS 2022 - Workshop on Principles of Distribution Shift, Jul 2022, Baltimore, United States. pp.1-8. ⟨hal-03697993v2⟩
107 Consultations
65 Téléchargements
