MERRIN: MEtabolic Regulation Rule INference from time series data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2022
Motivation: Many techniques have been developed to infer Boolean regulations from a prior knowledge network and experimental data. Existing methods are able to reverse-engineer Boolean regulations for transcriptional and signaling networks, but they fail to infer regulations that control metabolic networks. Results: We present a novel approach to infer Boolean rules for metabolic regulation from time series data and a prior knowledge network. Our method is based on a combination of answer set programming and linear programming. By solving both combinatorial and linear arithmetic constraints we generate candidate Boolean regulations that can reproduce the given data when coupled to the metabolic network. We evaluate our approach on a core regulated metabolic network and show how the quality of the predictions depends on the available kinetic, fluxomics or transcriptomics time series data.
Tuillier-O-2022.pdf (704.31 Ko) Télécharger le fichier
Origine : Publication financée par une institution
Licence : Copyright (Tous droits réservés)
hal-03701755 , version 1 (22-06-2022)
hal-03701755 , version 2 (27-10-2022)
Kerian Thuillier, Caroline Baroukh, Alexander Bockmayr, Ludovic Cottret, Loïc Paulevé, et al.. MERRIN: MEtabolic Regulation Rule INference from time series data. Bioinformatics, 2022, 38 (Supplement_2), pp.ii127-ii133. ⟨10.1093/bioinformatics/btac479⟩. ⟨hal-03701755v2⟩
176 Consultations
152 Téléchargements
