Adaptation to a changing environment: what me Normal? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Predicting the adaptation of populations to a changing environment is crucial to assess the impact of human activities on biodiversity. Many theoretical studies have tackled this issue by modeling the evolution of quantitative traits subject to stabilizing selection around an optimum phenotype, whose value is shifted continuously through time. In this context, the population fate results from the equilibrium distribution of the trait, relative to the moving optimum. Such a distribution may vary with the shape of selection, the system of reproduction, the number of loci, the mutation kernel or their interactions. Here, we develop a methodology that provides quantitative measures of population maladaptation and potential of survival directly from the entire profile of the phenotypic distribution, without any a priori on its shape. We investigate two different models of reproduction (asexual and infinitesimal sexual models of inheritance), with general forms of selection. In particular, we recover that fitness functions such that selection weakens away from the optimum lead to evolutionary tipping points, with an abrupt collapse of the population when the speed of environmental change is too high. Our unified framework furthermore allows highlighting the underlying mechanisms that lead to this phenomenon. More generally, it allows discussing similarities and discrepancies between the two reproduction models, the latter being ultimately explained by different constraints on the evolution of the phenotypic variance. We demonstrate that the mean fitness in the population crucially depends on the shape of the selection function in the sexual infinitesimal model, in contrast with the asexual model. In the asexual model, we also investigate the effect of the mutation kernel and we show that kernels with higher kurtosis tend to reduce maladaptation and improve fitness, especially in fast changing environments.
Adaptation_changing environment_draft_nolinumber.pdf (1.86 Mo) Télécharger le fichier
hal-03702032 , version 1 (23-06-2022)
hal-03702032 , version 2 (31-01-2023)
hal-03702032 , version 3 (21-04-2023)
hal-03702032 , version 4 (28-05-2023)
Jimmy Garnier, O Cotto, T Bourgeron, E Bouin, T Lepoutre, et al.. Adaptation to a changing environment: what me Normal?. 2022. ⟨hal-03702032v1⟩
234 Consultations
127 Téléchargements
