C3−H Silylation of Furfurylimines: Direct Access to a Novel Biobased Versatile Synthetic Platform Derived from Furfural - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Asian Journal of Organic Chemistry Année : 2022
Herein we report directed iridium-catalyzed C3-H silylation of furfuryl imines, which grants access to versatile synthetic platforms. This transformation was developed on furfuryl derivatives, using imines as directing groups, and trialkylsilanes or bis(trimethylsilyl)methylsilane as silylating agents, in the presence of a hydride scavenger. Subsequently, fluoride-mediated activation strategies were applied to the C3-SiMe(OSiMe3)2 furfural derivatives to achieve a wide range of transformations of the C3-Si bond. Arylation, alkenylation, alkynylation, allylation and alkylation, as well as halogenation and trifluoromethylation were achieved in modest to high yields. A variety of high value-added products were thus easily obtained from the same common C3-silylated furfural-based platform.
ajoc.202200199_Accepeted version.pdf (1.25 Mo) Télécharger le fichier
hal-03713537 , version 1 (04-07-2022)
Sebastien Curpanen, Giovanni Poli, Alejandro Pérez-Luna, Julie Oble. C3−H Silylation of Furfurylimines: Direct Access to a Novel Biobased Versatile Synthetic Platform Derived from Furfural. Asian Journal of Organic Chemistry, 2022, 11, pp.e202200199. ⟨10.1002/ajoc.202200199⟩. ⟨hal-03713537⟩
116 Consultations
38 Téléchargements
