A structure preserving hybrid finite volume scheme for semi-conductor models with magnetic field on general meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
We are interested in the discretisation of a drift-diffusion system in the framework of hybrid finite volume (HFV) methods on general polygonal/polyhedral meshes. The system under study is composed of two anisotropic and nonlinear convection-diffusion equations coupled with a Poisson equation and describes in particular semiconductor devices immersed in a magnetic field. We introduce a new scheme based on an entropy-dissipation relation and prove that the scheme admits solutions with values in admissible sets-especially, the computed densities remain positive. Moreover, we show that the discrete solutions to the scheme converge exponentially fast in time towards the associated discrete thermal equilibrium. Several numerical tests confirm our theoretical results.
SC_HFV.pdf (1.37 Mo) Télécharger le fichier
hal-03715313 , version 1 (06-07-2022)
hal-03715313 , version 2 (09-05-2023)
  • HAL Id : hal-03715313 , version 1
Julien Moatti. A structure preserving hybrid finite volume scheme for semi-conductor models with magnetic field on general meshes. 2022. ⟨hal-03715313v1⟩
97 Consultations
52 Téléchargements
