Finite elements for Wasserstein $W_p$ gradient flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
Convergence of a finite element discretization of a degenerate parabolic equation of $q$-Laplace type with an additional external potential is considered. The main novelty of our approach is that we use the underlying gradient flow structure in the $L^p$-Wasserstein metric: from the abstract machinery of metric gradient flows, convergence of scheme is obtained solely on the basis of estimates that result naturally from the equation's variational structure. In particular, the limit is identified as the unique gradient flow solution without reference to monotonicity methods.
FE4WpGF_preprint.pdf (1.89 Mo) Télécharger le fichier
hal-03719189 , version 1 (11-07-2022)
  • HAL Id : hal-03719189 , version 1
Clément Cancès, Daniel Matthes, Flore Nabet, Eva-Maria Rott. Finite elements for Wasserstein $W_p$ gradient flows. 2024. ⟨hal-03719189⟩
117 Consultations
122 Téléchargements
