Optimal homotopy reconstruction results à la Niyogi, Smale, and Weinberger
In this article we show that the proof of the homotopy reconstruction result by Niyogi, Smale, and Weinberger can be streamlined considerably using Federer's work on the reach and several geometric observations. While Niyogi, Smale, and Weinberger restricted themselves to C 2 manifolds (M) with positive reach, our proof extends to sets (S) of positive reach. The sample we consider does not have to lie directly on the set of positive reach. Instead, we assume that the two one-sided Hausdorff distances (δ and ε)-between the sample P to the set S, are bounded. We provide explicit bounds in terms of ε and δ, that guarantee that there exists a parameter r such that the union of balls p∈P B(p, r) deformation retracts to S. We provide even better bounds for the manifold case. In both cases, our bounds improve considerably on the state-of-the-art in almost all settings. In fact the bounds are optimal.
Géométrie algorithmique [cs.CG]
