Quantification Annotation in ISO 24617-12, Second Draft - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maxime Amblard
Philippe de Groote
Bruno Guillaume
Chuyuan Li
Pierre Ludmann
Siyana Pavlova
Guy Perrier
  • Fonction : Auteur
  • PersonId : 8101
  • IdHAL : guy-perrier
This paper describes the continuation of a project that aims at establishing an interoperable annotation scheme for quantification phenomena as part of the ISO suite of standards for semantic annotation, known as the Semantic Annotation Framework. After a break, caused by the Covid-19 pandemic, the project was relaunched in early 2022 with a second working draft, which deals with certain issues in the annotation of quantification in a more satisfactory way than the original first working draft.
lrec2022-Quant-v2.pdf (313.65 Ko) Télécharger le fichier
hal-03724057 , version 1 (15-07-2022)
  • HAL Id : hal-03724057 , version 1
Harry Bunt, Maxime Amblard, Johan Bos, Karën Fort, Philippe de Groote, et al.. Quantification Annotation in ISO 24617-12, Second Draft. Proceedings of the 13th Language Resources and Evaluation Conference (LREC 2022), Jun 2022, Marseille, France. pp.3407--3416. ⟨hal-03724057⟩
99 Consultations
63 Téléchargements
