A Result on Controllability with Constrained Controls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This talk will be about local controllability of a control affine system along a reference solution x(.), defined on [0,T], corresponding to zero control, in the case where the zero control is on the boundary of the set U that constrains the control. We present a sufficient condition for the reachable set in time T from x(0) (with U-valued controls) to be a neighborhood of x(T). If U was a neigborhood of the zero control, it would be nothing but the first order condition stating that x(.) is not a singular solution. When the zero control is on the boundary, it relies on convex inequalities rather than a mere Lie Brackets computation, but the proof is still first order in essence. In the case where the drift vector field has only periodic solutions, this yields local controllability over one period, and global controlability in long time. The motivation for this work was about control of solar sails. We will explain how this allows, for these devices, to prove controllability under some properties of the reflectivity/absobtion parameters of the sail and disprove controllabil- ity (at least local controllability over one period) for other values. Note that checking the condition has to be done numerically and involves a non trivial translation into convex optimization.
2022-Rouen-commandabilite-handout.pdf (1.09 Mo) Télécharger le fichier
hal-03726247 , version 1 (18-07-2022)
  • HAL Id : hal-03726247 , version 1
Jean-Baptiste Pomet, Jean-Baptiste Caillau, Lamberto Dell'Elce, Alesia Herasimenka. A Result on Controllability with Constrained Controls. Workshop on Optimal Control Theory, Jun 2022, Rouen, France. ⟨hal-03726247⟩
48 Consultations
33 Téléchargements
