Bringing Life out of Diversity: Boosting Network Lifetime using Multi-PHY Routing in RPL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transactions on emerging telecommunications technologies Année : 2022
Mina Rady
  • Fonction : Auteur
  • PersonId : 1062727
Quentin Lampin
  • Fonction : Auteur
  • PersonId : 1123783
Dominique Barthel
  • Fonction : Auteur
  • PersonId : 847534
In this article, we propose a routing mechanism based on the RPL protocol in a wireless network that is equipped with a mix of short-range and long-range radios. We introduce Life-OF, an objective function for RPL which uses a combination of metrics and the diverse physical layers to boost the network's lifetime. We evaluate the performance of Life-OF compared to the classical MRHOF objective function in simulations. Two key performance indicators (KPIs) are reported: network lifetime and network latency. Results demonstrate that MRHOF tends to converge to a pure long-range network, leading to short network lifetime. However, Life-OF improves network lifetime by continuously adapting the routing topology to favor routing over nodes with longest remaining lifetime. Life-OF combines diverse radios and balances power consumption in the network. This way, nodes switch between using their short-range radio to improve their own battery lifetime and using their long-range radio to avoid routers that are close to depletion. Results show that using Life-OF improves the lifetime of the network by up to 470% that of MRHOF, while maintaining similar latency.
Fichier non déposé
hal-03726255 , version 1 (07-06-2022)
hal-03726255 , version 2 (18-07-2022)
Mina Rady, Quentin Lampin, Dominique Barthel, Thomas Watteyne. Bringing Life out of Diversity: Boosting Network Lifetime using Multi-PHY Routing in RPL. Transactions on emerging telecommunications technologies, 2022, ⟨10.1002/ett.4592⟩. ⟨hal-03726255v1⟩
77 Consultations
57 Téléchargements
