Polynomials with maximal differential uniformity and the exceptional APN conjecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) Journal of Algebra Année : 2023
We contribute to the exceptional APN conjecture by showing that no polynomial of degree m = 2 r (2 ℓ + 1) where gcd(r, ℓ) 2, r 2, ℓ 1 with a nonzero second leading coefficient can be APN over infinitely many extensions of the base field. More precisely, we prove that for n sufficiently large, all polynomials of F 2 n [x] of such a degree with a nonzero second leading coefficient have a differential uniformity equal to m − 2.
Aubry_Herbaut_Issa_220726.pdf (218.68 Ko) Télécharger le fichier
hal-03739111 , version 1 (26-07-2022)
Yves Aubry, Ali Issa, Fabien Herbaut. Polynomials with maximal differential uniformity and the exceptional APN conjecture. Journal of Algebra, 2023, 635, pp.822-837. ⟨10.1016/j.jalgebra.2023.07.017⟩. ⟨hal-03739111⟩
142 Consultations
51 Téléchargements
