Automatic Tuning and Selection of Whole-Body Controllers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Designing controllers for complex robots such as humanoids is not an easy task. Often, researchers hand-tune controllers, but this is a time-consuming approach that yields a single controller which cannot generalize well to varied tasks. This work presents a method which uses the NSGA-II multi-objective optimization algorithm with various training trajectories to output a diverse Pareto set of well-functioning controller weights and gains. The best of these are shown to also work well on the real Talos robot. The learned Pareto front is then used in a Bayesian optimization (BO) algorithm both as a search space and as a source of prior information in the initial mean estimate. This combined learning approach, leveraging the two optimization methods together, finds a suitable parameter set for a new trajectory within 20 trials and outperforms both BO in the continuous parameter search space and random search along the precomputed Pareto front. The few trials required for this formulation of BO suggest that it could feasibly be applied on the physical robot using a Pareto front generated in simulation.
Automatic_Tuning_and_Selection_of_Whole_Body_Controllers.pdf (26.98 Mo) Télécharger le fichier
hal-03740361 , version 1 (29-07-2022)
  • HAL Id : hal-03740361 , version 1
Evelyn D'Elia, Jean-Baptiste Mouret, Jens Kober, Serena Ivaldi. Automatic Tuning and Selection of Whole-Body Controllers. 2022 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS), Oct 2022, Kyoto, Japan. ⟨hal-03740361⟩
103 Consultations
45 Téléchargements
