Equivalent Formulations of Optimal Control Problems with Maximum Cost and Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Optimization Theory and Applications Année : 2022
We revisit the optimal control problem with maximum cost with the objective to provide different equivalent reformulations suitable to numerical methods. We propose two reformulations in terms of extended Mayer problems with state constraints, and another one in terms of a differential inclusion with upper-semi continuous right member without state constraint. For the latter we also propose a scheme that approximates from below the optimal value. These approaches are illustrated and discussed in several examples.
min_peak.pdf (544.92 Ko) Télécharger le fichier
hal-03746480 , version 1 (05-08-2022)
Paternité
Emilio Molina, Alain Rapaport, Héctor Ramírez. Equivalent Formulations of Optimal Control Problems with Maximum Cost and Applications. Journal of Optimization Theory and Applications, 2022, 195, pp.953-975. ⟨10.1007/s10957-022-02094-z⟩. ⟨hal-03746480⟩
102 Consultations
50 Téléchargements
