Asymptotic-Möbius maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Roughly speaking, a map between metric spaces is asymptotically Möbius if it induces quasi-Möbius maps on asymptotic cones. We show that under such maps, some large-scale notions of dimension increases: asymptotic dimension for finitely generated nilpotent groups, telescopic dimension for CAT (0) spaces.
LSQM-maps.pdf (249.17 Ko) Télécharger le fichier
hal-03746707 , version 1 (05-08-2022)
hal-03746707 , version 2 (23-08-2022)
hal-03746707 , version 3 (24-08-2022)
hal-03746707 , version 4 (16-12-2022)
hal-03746707 , version 5 (21-02-2023)
  • HAL Id : hal-03746707 , version 2
Georg Alexander Gruetzner. Asymptotic-Möbius maps. 2022. ⟨hal-03746707v2⟩
141 Consultations
89 Téléchargements
