Transformation-based Refactorings: a First Analysis
Refactorings are behavior preserving transformations. Little work exists on the analysis of their implementation and in particular how refactorings could be composed from smaller, reusable, parts (being simple transformations or other refactorings) and how (non behavior preserving) transformations could be used in isolation or to compose new refactoring operators. In this article we study the seminal implementation and evolution of Refactorings as proposed in the PhD of D. Roberts. Such an implementation is available as the Refactoring Browser package in Pharo. In particular we focus on the possibilities to reuse transformations independently from the behavior preserving aspect of a refactoring. The long term question we want to answer is: Is it possible to have more atomic transformations and refactorings composed out of such transformations? We study preconditions of existing refactorings and identify several families. We identify missed opportunities of reuse in the case of implicit composite refactorings. We analyze the refactorings that are explicitly composed out of other refactorings to understand whether the composition could be expressed at another level of abstraction. This analysis should be the basis for a more systematic expression of composable refactorings as well as the reuse of logic between transformations and refactorings.
Langage de programmation [cs.PL]
