Combining chaotic dynamical systems using the fuzzy logic XOR operator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we explore whatever combining two chaotic dynamical systems using the fuzzy logic operator XOR can maintain or not the chaotic properties of the resulting dynamical system. This study is motivated by techniques used in applications to secure communications ,images encryption and cryptography.
gharout-chemlal.pdf (304.87 Ko) Télécharger le fichier
hal-03753636 , version 1 (18-08-2022)
  • HAL Id : hal-03753636 , version 1
Rezki Chemlal, Hacene Gharout. Combining chaotic dynamical systems using the fuzzy logic XOR operator. CARI 2022, Oct 2022, Tunis, Tunisia. ⟨hal-03753636⟩
Collections
CARI2022
90 Consultations
71 Téléchargements
