Reminiscence of classical chaos in driven transmons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PRX Quantum Année : 2023
Transmon qubits are ubiquitously used in quantum information processing architectures based on superconducting circuits. Because of their lifetime, strong drives are required to realize fast, high-fidelity, gates and measurements, including parametrically activated processes. Here, we show that even off-resonant drives, in regimes routinely used in experiments, can cause strong modifications to the structure of the transmon spectrum rendering a large part of it chaotic. Accounting for the full nonlinear dynamics in a Floquet-Markov formalism, we find that the coherence time of the computational states of transmons can be significantly altered in the presence of a chaotic layer. In particular, chaos-assisted quantum phase slips greatly enhance band dispersions. In the presence of a measurement resonator, we find that approaching chaotic behavior correlates with strong transmon-resonator hybridization, and an average resonator response centered on the bare resonator frequency. The phenomena described here should be present in all circuits based on low-impedance Josephson-junctions.
hal-03758792 , version 1 (23-08-2022)
Paternité
Joachim Cohen, Alexandru Petrescu, Ross Shillito, Alexandre Blais. Reminiscence of classical chaos in driven transmons. PRX Quantum, 2023, 4 (2), pp.020312. ⟨10.1103/PRXQuantum.4.020312⟩. ⟨hal-03758792⟩
95 Consultations
0 Téléchargements
