Themis: an On-Site Voting System with Systematic Cast-as-intended Verification and Partial Accountability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mikaël Bougon
  • Fonction : Auteur
  • PersonId : 1159155
Hervé Chabanne
  • Fonction : Auteur
  • PersonId : 1039812
Véronique Cortier
  • Fonction : Auteur
  • PersonId : 990209
Alexandre Debant
  • Fonction : Auteur
  • PersonId : 1028184
Emmanuelle Dottax
  • Fonction : Auteur
Jannik Dreier
Mathieu Turuani
  • Fonction : Auteur
  • PersonId : 1159156
We propose an on-site voting system Themis, that aims at improving security when local authorities are not fully trusted. Voters vote thanks to voting sheets as well as smart cards that produce encrypted ballots. Electronic ballots are systematically audited, without compromising privacy. Moreover, the system includes a precise dispute resolution procedure identifying misbehaving parties. We conduct a full formal analysis of Themis using ProVerif, with a novel approach in order to cover the modular arithmetic needed in our protocol. In order to evaluate the usability of our system, we organized a voting experiment on a (small) group of voters.
main-hal.pdf (1.26 Mo) Télécharger le fichier
hal-03763294 , version 1 (29-08-2022)
hal-03763294 , version 2 (11-05-2023)
Mikaël Bougon, Hervé Chabanne, Véronique Cortier, Alexandre Debant, Emmanuelle Dottax, et al.. Themis: an On-Site Voting System with Systematic Cast-as-intended Verification and Partial Accountability. CCS 2022 - The ACM Conference on Computer and Communications Security, Nov 2022, Los Angeles, United States. ⟨10.1145/3548606.3560563⟩. ⟨hal-03763294v1⟩
253 Consultations
270 Téléchargements
