Over one Century of Spectrum Analysis in Delay Systems: An Overview and New Trends in Pole Placement Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pole placement represents a classical method for controlling finite-dimensional linear timeinvariant systems, largely covered in the open literature. Basically, it consists of placing the poles of the closed-loop system in some predetermined loci in the complex plane. This paper discusses some of the extensions of this method to linear systems described by delay-differential equations. Among others, the finite spectrum assignment (FSA), the continuous pole placement (CPP) and the partial pole placement (PPP) approaches are presented and illustrated through some simple low-order dynamical systems.
TDS A 2022.pdf (225.07 Ko) Télécharger le fichier
hal-03765146 , version 1 (30-08-2022)
Amina Benarab, Islam Boussaada, Silviu-Iulian Niculescu, Karim Trabelsi. Over one Century of Spectrum Analysis in Delay Systems: An Overview and New Trends in Pole Placement Methods. TDS 2022 - 17th IFAC Workshop on Time Delay Systems, Sep 2022, Montreal, Canada. ⟨10.1016/j.ifacol.2022.11.363⟩. ⟨hal-03765146⟩
77 Consultations
88 Téléchargements
