Lifting Numeric Relational Domains to Algebraic Data Types (extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2022
We present RAND, a relational abstract domain that expresses relations between values of non-recursive algebraic data types (ADTs), and numeric relations between their scalar parts. RAND is parametrised on a user-provided numeric relational domain, that we lift to pairs of variables and projection paths. It is constructed as a disjunctive completion of a reduced product of domains for numeric relations, for equalities, and for cases of variant constructors. Using RAND, we define a modular, inter-procedural, relational analysis for a while language with ADTs and function calls. The analysis computes function summaries, that describe relations between the inputs of programs and their outputs.
sas2022.pdf (5.46 Mo) Télécharger le fichier
hal-03765357 , version 1 (31-08-2022)
hal-03765357 , version 2 (01-09-2022)
hal-03765357 , version 3 (16-09-2022)
hal-03765357 , version 4 (26-06-2023)
  • HAL Id : hal-03765357 , version 1
Santiago Bautista, Thomas Jensen, Benoît Montagu. Lifting Numeric Relational Domains to Algebraic Data Types (extended version). [Research Report] Centre Inria de l'Université de Rennes; Univ Rennes. 2022. ⟨hal-03765357v1⟩
388 Consultations
51 Téléchargements
