Runtime Enforcement for IEC 61499 Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Industrial automation is a complex process involving various stakeholders. The international standard IEC 61499 helps to specify distributed automation using a generic architectural model, targeting the technical development of the automation. However, analysing the correctness of IEC 61499 models remains a challenge because of their informal semantics and distributed logic. We propose new verification techniques for IEC 61499 applications. These techniques rely on the concept of runtime enforcement, which can be applied to systems for preventing bad behaviours from happening. The main idea of our approach is to integrate an enforcer in the application for allowing it to respect specific properties when executing. The techniques begin with the definition of a property. The language of this property supports features such as discarding and replacing events. Next, this property is used to synthesise an enforcer in the form of a function block. Finally, the synthesised enforcer is integrated into the application. Our approach is illustrated on a realistic example and fully automated.
main.pdf (1.05 Mo) Télécharger le fichier
hal-03766095 , version 1 (31-08-2022)
hal-03766095 , version 2 (24-03-2023)
Yliès Falcone, Irman Faqrizal, Gwen Salaün. Runtime Enforcement for IEC 61499 Applications. SEFM 2022 - 20th International Conference on Software Engineering and Formal Methods, Sep 2022, Berlin, Germany. pp.1-17, ⟨10.1007/978-3-031-17108-6_22⟩. ⟨hal-03766095v1⟩
108 Consultations
309 Téléchargements
