From Static to Dynamic Analysis and Allocation of Resources for BPMN Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Business process optimisation is a strategic activity in organisations because of its potential to increase profit margins and reduce operational costs. One of the main challenges in this context is concerned with the problem of optimising the allocation and sharing of resources. In this work, processes are described using the BPMN notation extended with an explicit description of execution time and resources associated with tasks, and can be concurrently executed multiple times. First, a simulation-based approach for computing certain metrics of interest, such as average execution time or resource usage, is presented. This approach applies off-line and is static in the sense that the number of resources does not evolve over the time of the simulation. In a second step, an alternative approach is presented, which works online, thus requiring the instrumentation of an existing platform for retrieving information of interest during the processes' execution. This second approach is dynamic because the number of resource replicas is updated over the time of the execution. This paper aims at stressing pros and cons of both approaches, and at showing how they complement each other.
From Static to Dynamic Analysis and Allocation of Resources for BPMN Processes.pdf (1.18 Mo) Télécharger le fichier
hal-03766148 , version 1 (31-08-2022)
Paternité
Francisco Durán, Yliès Falcone, Camilo Rocha, Gwen Salaün, Ahang Zuo. From Static to Dynamic Analysis and Allocation of Resources for BPMN Processes. WRLA 2022 - 14th International Workshop on Rewriting Logic and its Applications, Apr 2022, Munich, Germany. pp.1-18, ⟨10.1007/978-3-031-12441-9_1⟩. ⟨hal-03766148⟩
69 Consultations
91 Téléchargements
