Efficient preconditioners for solving dynamical optimal transport via interior point methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
In this paper we address the numerical solution of the quadratic optimal transport problem in its dynamical form, the so-called Benamou-Brenier formulation. When solved using interior point methods, the main computational bottleneck is the solution of large saddle point linear systems arising from the associated Newton-Raphson scheme. The main purpose of this paper is to design efficient preconditioners to solve these linear systems via iterative methods. Among the proposed preconditioners, we introduce one based on the partial commutation of the operators that compose the dual Schur complement of these saddle point linear systems, which we refer as $\boldsymbol{B}\boldsymbol{B}$-preconditioner. A series of numerical tests show that the $\boldsymbol{B}\boldsymbol{B}$-preconditioner is the most efficient among those presented, with a CPU-time scaling only slightly more than linearly with respect to the number of unknowns used to discretize the problem.
arxiv_main.pdf (525.38 Ko) Télécharger le fichier
hal-03766668 , version 1 (01-09-2022)
hal-03766668 , version 2 (04-05-2023)
hal-03766668 , version 3 (22-01-2024)
Enrico Facca, Gabriele Todeschi, Andrea Natale, Michele Benzi. Efficient preconditioners for solving dynamical optimal transport via interior point methods. 2022. ⟨hal-03766668v2⟩
144 Consultations
41 Téléchargements
