Symmetric Block-Cyclic Distribution: Fewer Communications Leads to Faster Dense Cholesky Factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the distributed Cholesky factorization on homogeneous nodes. Inspired by recent progress on asymptotic lower bounds on the total communication volume required to perform Cholesky factorization, we present an original data distribution, Symmetric Block Cyclic (SBC), designed to take advantage of the symmetry of the matrix. We prove that SBC reduces the overall communication volume between nodes by a factor of square root of 2 compared to the standard 2D blockcyclic distribution. SBC can easily be implemented within the paradigm of task-based runtime systems. Experiments using the Chameleon library over the StarPU runtime system demonstrate that the SBC distribution reduces the communication volume as expected, and also achieves better performance and scalability than the classical 2D block-cyclic allocation scheme in all configurations. We also propose a 2.5D variant of SBC and prove that it further improves the communication and performance benefits.
final_version_no_copyright.pdf (413.54 Ko) Télécharger le fichier
hal-03768910 , version 1 (05-09-2022)
  • HAL Id : hal-03768910 , version 1
Olivier Beaumont, Philippe Duchon, Lionel Eyraud-Dubois, Julien Langou, Mathieu Vérité. Symmetric Block-Cyclic Distribution: Fewer Communications Leads to Faster Dense Cholesky Factorization. SC 2022 - Supercomputing, Nov 2022, Dallas, Texas, United States. ⟨hal-03768910⟩
207 Consultations
942 Téléchargements
