CATREEN: Context-Aware Code Timing Estimation with Stacked Recurrent Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
Automatic prediction of the execution time of programs for a given architecture is crucial, both for performance analysis in general and for compiler designers in particular. In this paper, we present CATREEN, a recurrent neural network able to predict the steady-state execution time of each basic block in a program. Contrarily to other models, CATREEN can take into account the execution context formed by the previously executed basic blocks which allows accounting for the processor micro-architecture without explicit modeling of micro-architectural elements (caches, pipelines, branch predictors, etc.). The evaluations conducted with synthetic programs and real ones (Programs from Mibench and Polybench) show that CATREEN can provide accurate prediction for execution time with 11.4% and 16.5% error on average, respectively and that we got an improvement of 18% and 27.6% respectively when comparing our tool estimations to the state-of-the-art LSTM-based model.
CATREEN_at_ICTAI_fullVersion.pdf (335.79 Ko) Télécharger le fichier
hal-03776508 , version 1 (13-09-2022)
  • HAL Id : hal-03776508 , version 1
Abderaouf Nassim Amalou, Élisa Fromont, Isabelle Puaut. CATREEN: Context-Aware Code Timing Estimation with Stacked Recurrent Networks. 2022. ⟨hal-03776508⟩
118 Consultations
103 Téléchargements
