Automatic extraction of materials and properties from superconductors scientific literature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) Science and Technology of Advanced Materials: Methods Année : 2022
The automatic extraction of materials and related properties from the scientific literature is gaining attention in data-driven materials science (Materials Informatics). In this paper, we discuss Grobid-superconductors, our solution for automatically extracting superconductor material names and respective properties from text. Built as a Grobid module, it combines machine learning and heuristic approaches in a multi-step architecture that supports input data as raw text or PDF documents. Using Grobid-superconductors, we built SuperCon2, a database of 40324 materials and properties records from 37700 papers. The material (or sample) information is represented by name, chemical formula, and material class, and is characterized by shape, doping, substitution variables for components, and substrate as adjoined information. The properties include the Tc superconducting critical temperature and, when available, applied pressure with the Tc measurement method.
main.pdf (1.16 Mo) Télécharger le fichier
hal-03776658 , version 1 (14-09-2022)
hal-03776658 , version 2 (20-11-2022)
Paternité
Luca Foppiano, Pedro Baptista de Castro, Pedro Ortiz Suarez, Kensei Terashima, Yoshihiko Takano, et al.. Automatic extraction of materials and properties from superconductors scientific literature. Science and Technology of Advanced Materials: Methods, 2022, ⟨10.1080/27660400.2022.2153633⟩. ⟨hal-03776658v2⟩
174 Consultations
248 Téléchargements
