Computing the Cut Locus of a Riemannian Manifold via Optimal Transport - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this paper, we give a new characterization of the cut locus of a point on a compact Riemannian manifold as the zero set of the optimal transport density solution of the Monge-Kantorovich equations, a PDE formulation of the optimal transport problem with cost equal to the geodesic distance. Combining this result with an optimal transport numerical solver based on the so-called dynamical Monge-Kantorovich approach, we propose a novel framework for the numerical approximation of the cut locus of a point in a manifold. We show the applicability of the proposed method on a few examples settled on 2d-surfaces embedded in $R^{3}$ and discuss advantages and limitations.
hal-03778833 , version 1 (06-12-2021)
hal-03778833 , version 2 (16-09-2022)
Enrico Facca, Luca Berti, Francesco Fassó, Mario Putti. Computing the Cut Locus of a Riemannian Manifold via Optimal Transport. 2021. ⟨hal-03778833v1⟩
130 Consultations
155 Téléchargements
