Embedded Topics in the Stochastic Block Model
Communication networks such as emails or social networks are now ubiquitous and their
analysis has become a strategic field. In many applications, the goal is to automatically
extract relevant information by looking at the nodes and their connections. Unfortu-
nately, most of the existing methods focus on analysing the presence or absence of edges
and textual data is often discarded. However, all communication networks actually come
with textual data on the edges. In order to take into account this specificity, we consider
in this paper networks for which two nodes are linked if and only if they share textual
data. We introduce a deep latent variable model allowing embedded topics to be handled
called ETSBM to simultaneously perform clustering on the nodes while modelling the
topics used between the different clusters. ETSBM extends both the stochastic block
model (SBM) and the embedded topic model (ETM) which are core models for study-
ing networks and corpora, respectively. The inference is done using a variational-Bayes
expectation-maximisation algorithm combined with a stochastic gradient descent. The
methodology is evaluated on synthetic data and on a real world dataset.
Keywords: Graph clustering, topic modelling, variational inference, generative model,
probabilistic model, embedded topic model, stochastic block model
