First cross dating (U/Th-14C) of calcite covering rock paintings in Africa: The case of the Lovo Massif, Democratic Republic of the Congo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Archaeological Science: Reports Année : 2022
Unlike the richly documented rock art of the Sahara or southern Africa, that of sub-Saharan Africa often remains poorly known. With 117 inventoried sites (including 20 decorated caves), the Lovo Massif contains one of the largest concentrations of rock sites in the entire region, representing more than 5700 images. Dating this rock art is a real challenge, and only a few direct dates of drawings made with charcoal have been obtained so far (Heimlich et al., 2013). In this paper, we present the first chronology for the red geometric paintings of the Lovo Massif. We used uranium-series and 14C on secondary carbonates deposited above a series of geometric paintings at the M'Bubulu rock art site, in order to propose a minimum age for these motifs. The cross-dating shows evidence of a close system behavior for these secondary carbonate layers, thereby validating the ages obtained. They can thus be used to constrain the chronology of the red geometric paintings, which were made before the seventeenth century. Thus, this art could be attributed to a specific Kongo ritual.
Heimlich2022.pdf (736.39 Ko) Télécharger le fichier
hal-03787943 , version 1 (13-09-2023)
Copyright (Tous droits réservés)
Geoffroy Heimlich, Edwige Pons-Branchu, Hélène Valladas, Arnaud Dapoigny, Jean-Pascal Dumoulin, et al.. First cross dating (U/Th-14C) of calcite covering rock paintings in Africa: The case of the Lovo Massif, Democratic Republic of the Congo. Journal of Archaeological Science: Reports, 2022, 45, pp.103623. ⟨10.1016/j.jasrep.2022.103623⟩. ⟨hal-03787943⟩
90 Consultations
81 Téléchargements
